PC computer computer
Thunderbolt is a high-speed data transfer interface jointly developed by Intel and Apple. It is compatible with USB4 and USB3 devices, and not only has fast transmission speeds, but can also connect multiple devices. With Thunderbolt, users can easily connect their computer directly to the NAS for high-speed data transfer. Thunderbolt is known for its ultra-fast transfer speeds. The latest Thunderbolt 4 interface can theoretically achieve a data transfer speed of 40 Gbps (Thunderbolt 4 standard, far exceeding traditional interfaces). Whether transferring large files or processing data in real time, Thunderbolt can significantly improve work efficiency.
Thunderbolt configurations supported by Green Union NAS
1. Supported NAS models
Devices such as the DXP480T Plus, DXP6800 Pro, and DXP8800 series are equipped with a Thunderbolt 4 interface and support Thunderbolt direct connection.
2. Cable requirements:
Use a certified Thunderbolt cable: Thunderbolt 3, Thunderbolt 4 or Thunderbolt 5 (usually marked with the Thunderbolt logo ⚡️).
3. Interface requirements:
The computer needs to support the Thunderbolt interface (Thunderbolt 3 and above).
Note:
Although the Type-C and Thunderbolt interfaces look the same, Thunderbolt uses a special communication protocol. A regular Type-C cable can only support the USB protocol and cannot provide the high-speed data transmission capabilities of the Thunderbolt protocol. For optimal performance, use a certified Thunderbolt cable.
If you want to use a direct Thunderbolt connection, we recommend that you use a Mac system first, as the transfer efficiency in macOS is higher. If you are a Windows user, you will need to install the driver manually and be aware of compatibility issues. In addition, Windows systems may experience a loss in upload speed.
Lightning direct connection operating steps
1. Physical connection:
Plug one end of the lightning cable into the lightning port on the Greenlink NAS and the other end into the lightning port on the computer (the lightning port is usually marked with a ⚡️).
