Test the modified title and test the binding of the translation to the node_PC
Check the situation on the PC side
Application description
Tailscale is a network connection tool based on WireGuard technology that is designed to help users quickly build secure private networks. Through its efficient peer-to-peer technology, Tailscale provides secure and reliable network connections. The following are its main features:
  • Based on the WireGuard protocol, all data transmission is encrypted, ensuring data security during transmission.
  • No complicated network configuration is required. Simply install the client and log in to your account to easily establish a direct connection between devices.
  • Supports multiple operating systems, including Linux, Windows, macOS, iOS and Android.
  • Peer-to-peer connections bypass central nodes, reducing latency and improving transmission efficiency.
  • Supports the construction of private cloud services such as file servers and game servers.
Tailscale is suitable for a variety of scenarios, such as when you are out and need to access your home or company's computer, NAS, and other devices. After installing the Tailscale client on your phone or computer and logging in with the same Tailscale account, all devices will automatically connect to the same virtual local area network, and you can access these devices as if they were local.
Preparation
Register for a Tailscale account
  1. Open the Tailscale login page.
  2. Choose a convenient login method, such as using a Microsoft account or an Apple account, and try out the other options as well.
