Try the content of the article on the control panel
Link to the access module
User management: add, edit and delete users, set user permissions and access controls.
File services: Manage file sharing services, supporting protocols such as SMB, NFS, FTP, WebDAV, and Rsync.
Device connection: Configure LAN connections and remote access methods such as UGREENlink and DDNS.
Domains and LDAP: Manage access rights for domain or LDAP users to system files.
Terminal: Provides Telnet/SSH access, which is only available to the administrator account.
General settings module
Hardware and power supply: Set the buzzer, cooling fan and LED indicators, and configure power management functions such as timed switching on and off and hard disk hibernation.
Time and language: Set the system time and language options.
Network settings: configure the network interface, default gateway, DNS server, enable multi-gateway and bridge mode.
Indexing service: Automatically indexes files and folders to improve search efficiency.
Security: Enable the firewall, configure IP blocking and whitelists, and manage certificates.
System service module
About this machine: view basic system information and hardware information such as storage space and hard disk status.
Update and restore: view the system version, and perform system updates and restore operations.
Please note: Only users with the administrator role can access the control panel. The normal user role cannot see the control panel.
