How to configure hosts
1、Configure the purpose of HOST
Mainland China users due to TMDB API DNS pollution, in general, can not be directly connected, you need to configure the system HOST to connect!
2、How to get TMDB domain name and ip correspondence
1) visithttps://dnschecker.org/网站
(2) enter the domain name api.themoviedb.org type selection A lookup
(3) to find the address is located in China, the IP copy down, according to the following format records
13.226.225.73 api.themoviedb.org
13.226.225.44 api.themoviedb.org
* The format is: ip space domain name
4) Similarly, we can get the ip addresses of the following domains as a supplement
image.themoviedb.org
www.themoviedb.org
3、If the configuration takes effect
1)Copy and paste the record ip address into the film and television centre-HOST quick configuration box, and check whether it meets the format requirements.
*Format Requirements
IP space domain name
One entry per line, multiple entries can be configured, multiple line feeds, maximum 100 lines.
*The input box of HOST configuration of Film and TV Centre is not restricted at present, in order to avoid unpredictable problems, please fill in HOST according to the above format requirements.
2)Check that there is no error, click [Import Configuration].
